edit: i've got a quick question about oc'ing at the end of the thread if anyone cares to lend a hand to a noob
Just installed my Athlon XP 1800 (retail). Upgraded from a Tbird 1.1ghz. Paired with a MSI K7T Turbo2 and PNY 512 pc133 (samsung).I've got bios revision 3.5 and it detects unknown CPU at 1533mhz. You think it's worth a bios flash just to get it to say Athlon XP at POST?
Also, bios tells me the vcore is running at 1.55 instead of the 1.60 the stepping info says it should be at...is there any potential in this (for OC)? I've read the websites about reading into the stepping codes...and if that were totally true, my cpu would be a 2700+....regardless of that, if I want to start OC'ing, should I wait awhile for the processor to 'burn in' before i up the fsb?
