my final cpu cooling solution
fastvideo
system 1) Duron 600@900 at 1.99v
system 2) slota t-bird 900@1150 at 1.75v.
before
system 1) with alpha6035 hsf max. temp between 48~50c.
system 2) with alpha7125 hsf max. temp between 45~48c.
with 85W peltier and 7125 hsf and 120mm fan sucking on top of the two heatsink fan with a ventilation pipe exhault on the side, max temp between 38~40c. MAKES LOTS OF NOISE!!!
now
spent 4 days making myself 2 waterblock.
system 1) 5/8X1.5X1.5 in. max temp between 38~40c.
system 2) 5/8X2X4 in. max temp between 35~38c.
a 170 gal. waterpump split for both systems.
A) no peltier this time, because what i found is, it just takes to much current and the amount of heat it created is much more difficult to take care of.
THINK ABOUT THIS BEFORE ORDERING ANY OF THOSE PELTIERS.
B) i am using a big bucket of water and place the radiator on top of the bucket and a 120mm fan in the center of the bucket blowing inside to create air circulation and cools the water temp.,i get 3c in difference.
from the results that i got is how to due with the water when it gets warm, just a small water tank and radiator doesn't help much.
THE BEST WATER TANK IS MY TOILET FLUSH TANK. FLASH COLD WATER EVERY 2~3 HOURS.
THINK ABOUT THIS BEFORE ORDERING ANY OF THOSE WATER COOLING KITS.
will post some pic of my setup when i finish up the mess that i have done for the last 4 days.
any better ideas, pls post here.
