Here is my final build specs for my new computer. IF anything screams out "no" please tell me. Also. I am still on the verge about 4870x2. I'm not sure I need it/it's worth it. I plan to CF in the future. So I would end up with 2 4870's anyway. And I've seen not much performance gain in benchmarks with 4870x2 X2. So I'm not sure about the Graphics Cards yet... everything else is pretty much finalized. I
I won't be using a 30inch monitor. I was thinking 24-28 with 1900x1200 native resolution.
I will be doing some gaming, but mostly using it for just about everything.
I will be learning to overclock with this rig, That's why i chose the Rampage Formula.
Thanks in advance.
Antec 900 PURCHASED
Corsair 750TX
ASUS Rampage Formula x48
QX6850 - PURCHASED
Diamond 4870 XOC (I MAY be able to afford 4870x2, but I don't feel I need it)
OCZ Reaper HTC DDR2-800 2x2GB. PURCHASED (Should I get another pair to make 8 GB Total)
Xigmatek HDT-S1283
Windows Vista Ultimate 64-bit
EDIT: Western Digital Caviar SE16 x2
I'm so eager, hopefully you will respond before I put all this on my credit card!
Thanks in advance.
Antec 900 PURCHASED
Corsair 750TX
QX6850 - PURCHASED
Xigmatek HDT-S1283
