I got my x800 yesterday and did some very quick benchmarks using the Benchemall program. The 9700Pro benches were taken a couple days ago using Omega 4.3 drivers. The x800Pro benches were done using the drivers that came on the CD. I did not check their version number. I'm using Windows XP Pro/SP1 and DX9.0b. I have not really done any tweaking to my system and I never shutdown background tasks when I play games. As a result programs like NAV and Internet Security are running in the background. I do use cacheman to make sure I have as much free memory as possible, typically around 770-780mb. Also my system is not overclocked at all.
My full system specs can be viewed here:
My current system
The only item that is not correct on that listing is my Mushkin PC3500 will arrive today so these benches were taken with 1GB of Crucial PC2700.
AMD64 3400+, 1 GB Crucial PC2700, 9700 Pro
Far Cry
Using Max settings.
Map: Fort Demo: BenchemallDefaultDemo
640x480
run# 0: Average FPS: 39.09
run# 1: Average FPS: 39.23
run# 2: Average FPS: 39.08
800x600
run# 0: Average FPS: 29.79
run# 1: Average FPS: 29.65
run# 2: Average FPS: 29.85
1024x768
run# 0: Average FPS: 21.80
run# 1: Average FPS: 21.79
run# 2: Average FPS: 21.81
1280x1024
run# 0: Average FPS: 12.02
run# 1: Average FPS: 12.02
run# 2: Average FPS: 12.03
1600x1200
run# 0: Average FPS: 9.05
run# 1: Average FPS: 9.09
run# 2: Average FPS: 9.06
Splinter Cell 1.2b
Demo name: 1_1_1TbilisiDemo.bin
800x600 Average= 49.015 fps, min 23.245 fps, max 106.345 fps. Effects quality= VERYHIGH
1024x768 Average= 44.861 fps, min 22.251 fps, max 106.186 fps. Effects quality= VERYHIGH
1280x1024 Average= 34.678 fps, min 18.970 fps, max 80.022 fps. Effects quality= VERYHIGH
1600x1200 Average= 30.487 fps, min 17.761 fps, max 66.675 fps. Effects quality= VERYHIGH
AMD64 3400+, 1 GB Crucial PC2700, x800 Pro
Far Cry
Using Max settings.
640x480
run# 0: Average FPS: 55.75
run# 1: Average FPS: 58.34
run# 2: Average FPS: 56.82
800x600
run# 0: Average FPS: 56.78
run# 1: Average FPS: 57.56
run# 2: Average FPS: 56.90
1024x768
run# 0: Average FPS: 56.75
run# 1: Average FPS: 57.37
run# 2: Average FPS: 57.61
1280x1024
run# 0: Average FPS: 55.38
run# 1: Average FPS: 56.90
run# 2: Average FPS: 56.93
1600x1200
run# 0: Average FPS: 48.75
run# 1: Average FPS: 49.51
run# 2: Average FPS: 49.09
Splinter Cell 1.2b
800x600 Average= 74.083 fps, min 40.515 fps, max 114.386 fps. Effects quality= VERYHIGH
1024x768 Average= 72.362 fps, min 42.149 fps, max 113.767 fps. Effects quality= VERYHIGH
1280x1024 Average= 67.247 fps, min 37.521 fps, max 114.825 fps. Effects quality= VERYHIGH
1600x1200 Average= 62.302 fps, min 36.097 fps, max 115.227 fps. Effects quality= VERYHIGH
I had been playing Far Cry with the 9700 at 800x600 resolution with many of the settings on Very High, Low AA and 1xAF. It was playable but the graphics tended to be shimmery at that resolution. Last night I played with everything at Very High, water at ultra high, 4xAF, Low AA at 1152x864 and it looked beautiful on the x800 and my framerates never dropped below mid 40's. I used Fraps to check in-game framerate.
I'm assuming that the PC2700 is creating a bottleneck at the CPU and that's why there is such a small spread between 640x480 and 1600x1200 on the x800. I'll bench again after I install the faster memory.
My current system
Far Cry
Using Max settings.
640x480
800x600
1024x768
1280x1024
1600x1200
Splinter Cell 1.2b
Far Cry
Using Max settings.
640x480
800x600
1024x768
1280x1024
1600x1200
Splinter Cell 1.2b
