- Jun 29, 2001
- 4,867
- 1
- 0
My video card is a ATI Radeon 9500 Pro, slightly overclocked. Antec Sonata with 2x 120mm fans running at ~5V. PSU fan replaced with a Panaflo running at ~7V and a Zalman CNPS-7000A running at ~5V. All hooked up to a Sunbeam fan controller.
Both fit nicely without any conflicts with the card or components around it. Both are pretty silent, well, the Zalman is dead silent. The VGA Silencer is definately much easier to install than the Zalman. The VGA Silencer is also much less messy with respect to thermal compound. If you have to remove the Zalman you'll know what I mean as you need plenty of compound at many different places compared to the one on the VGA Silencer.
I did not notice any temperature drops in my low airflow system. But then again I didn't do any real tests, but it does not seem like it helped temps. Noise is low enough that it doesn't add to overall system noise. Note that my system now is so quiet that you can't hear it a few feet away.
If I were to buy only one I'd buy the VGA Silencer because it's cheaper and it's much easier to install. I haven't tested overclocking yet, but I don't really have the time to
