My electric dryer crapped out.
xboxist
3,017
It's a GE stackable for my little tiny condo. I bought it new three years ago.
Symptoms:
--About 3-4 weeks ago I noticed that loads weren't fully dry after one cycle; slowly worsened until this past weekend when a load took two full cycles to dry completely
--Then just this past Sunday, when I went to remove the dried load I noticed that it absolutely reeked. Completely caught me offguard. It's certainly not mold, but I can't pinpoint it. Maybe like a weird burn smell? The load smelled nice and fresh out of the washer.
--I checked the lint vent/duct thing and it's perfectly clear all the way to the exterior of the building.
--Lint screen is clean.
--I asked my cat if she peed in the dryer and she said no.
I guess it's just something mechanical/electrical in the guts of the machine?
UPDATE***
Ok, I had GE come out and take a look at things. Unfortunately, this story has a sad ending.
The dryer itself checked out just fine. The problem was that the air vent passage to the exterior of the building was clogged.
A bird built a nest just inside of the duct (presumably a few weeks ago when my dryer started to work more slowly). And then last week sometime, the condo association had a guy go around and put these critter-proof grills on the outside wall over those ducts. I guess the dumbfvck didn't notice the birds already living there.
So yeah, they died a horrible death and I was smelling their aftermath. Lovely. :disgust: :(
Anyway, thanks for the responses.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Make sure the blower is working and nothing crawled in there (this time of the year mice seem to pop out of AC units - perhaps when they pop out they're running to driers.) Ask the cat if she's seen Jerry around the drier! ;)
If a resistance heater does not get sufficient airflow either due to a faulty blower or a restriction the coils will heat up. Some housings may be protected by a snap disk limit switch which is like a circuit breaker - when it cools, it snaps back and resumes normal operation. Other designs employ a fuse like element what's known as a microtemp - Text. If that tests open with an ohmmeter it needs to be replaced. NEVER jump it out - the ohm meter can test elements and relays too so even for the sake of "testing purposes" the microtemp should NEVER be jumped. 240VAC residential driers are ~5.5 kW and a malfunction will start a fire fast! When the nichrome gets too hot and breaks it will fall to the chassis with a much shorter path and the cycle runs quite fast - arc welder style (until the CB, typically 30A double pole in the US) opens but with the lint and heaven knows what else is nearby, a fire is certain.
If this intimidates you, call a qualified repairman/woman ASAP.
xboxist
3,017
:Q *calls GE*
(hehe, thanks -- I'm in over my head here)
