My DIY recycled, retro, and really Neat-0 amplifier enclosure.
This is my most recent Art Metal project. I've also been working on my own LM3875 amplifier boards that should fit inside just fine, with plenty of room for a volume potentiometer. (the PSU would be outboard.)
The sides are Socket 370 heatsinks leftover from dead PC's, the lexan was a piece of scrap I found, and the copper bits were leftovers from someone else's project. The epoxy, however, was not recycled.
It's not done yet - I'm adding a small faceplate, polishing it, and adding a clear varnish to the colored-metal bits to bring out their color better. And building a second one, having learned a few things from the first.
(If you're wondering, I applied bits of flux to the shaped piece of metal, and heated it, while cooling it carefully. End result? Pretty oxidation. The texture was produced by good, old-fashioned hammering.)
A note: I'll be building quite a few of these for my Art Metal class, and many will be for sale, either as boxes or as completed Gainclone amplifiers.
http://img90.imageshack.us/my.php?image=boxyv2.jpg]
[/URL]
It's a lot smaller than I expected. 🙂 I read "amplifier" and I was thinking rackmount size.
This is for a headphone amp, right? It's attractive; very austere and industrial looking. Good job. :thumbsup:
You're right - it's dinky. Only about seven centimeters tall by 18 centimeters wide. (Yes, I use metric. Much, much easier to scale things.)
Actually, it's not for a headphone amp - those big metal things are heatsinks. It's for a gainclone, capable of 30 watts per channel. (This is a "real" value, not some intangible "music power" value. They're actually rated for up to 56wpc.)
Yes, it's really, really small. I'm going to cram a 12-step ladder attenuator and dual class-A buffers (essentially a zero-gain class A preamp) in there, too.
The power supply is outboard, of course, and built into a cheap box from RadioShack. I'm probbably going to use ethernet cable or another twisted-pair wire to supply power to reduce hum even further.
And this is only the first - I'm working on a second one, built even better, with bigger heatsinks. That one will be used with an inboard PSU, and look a bit more "normal".
More news!
I'm re-working the PCB. If my prototypes (which are going in this amp) work, I'll order a bunch from Olimex. Then, amps galore!
Also, I located a motorized ALPS volume pot. Not a stepped attenuator, but much less hassle, and easily remote controlled.
