Platypus
Ok so I wanted a project for the summer, and I just started to formulate it now. This is pretty random so if you don't care to read any further, don't bother.
My roommates and I built a really awesome bar(lol alcoholic) that is going to rival all. It has a window cut out for a fish tank that will go inside it. Black lights to illuminate it. Black smoked plexiglass counter top for making drinks, a spot for a mini fridge, shelves for bottles, and most importantly a cabinet for my old FreeBSD box. I decided that I wanted to create something unique and I think I am going to do so very soon. I plan to rig up the BSD box to connect to my television, connect it to speakers, and run a massive virtual jukebox off of it, streaming music from my other box. I will use an IR remote control to change songs from within FreeBSD and I will run X on my television display so you can see a playlist. From there I decided to take it a step further. I am going to get an LED sign that scrolls the ID3 tags of the current song on my playlist and mount it on the front of the bar. That way, party guests can see what song is currently going and it will force me to try and get some coding done for it. That's about it, if you've read all this thanks for sticking with me.
