Dankk
About two weeks ago, I built a brand new computer. This is my first build, so I learned some things along the way, but overall it went quite well and I've gradually tweaked it and worked out it's kinks over time.
There is, however, ONE thing that I would still like to resolve: My cooling system.
My processor idles at around 43 celsius, until I play something intensive like Crysis, then it goes up to around 52 (I use realtemp). I've come to believe that these are rather crappy temperatures when I always hear people talking about their CPU's idling at well below 30.
Here is my case: Cooler Master Centurion 5
Here is my processor fan (the worst offender when it comes to noise): Masscool 90mm Ball CPU Cooler
Big question: Does the computer case play a significant factor in my CPU temperatures, to the point where I should try getting a new case? (Antec 900?)
It bothers me how the two items I listed above happen to be very popular on Newegg; like the case for example... people talk about what good airflow it has, when airflow seems to suck for me. People talk about how that masscool HSF is so quiet and effective, but it's none of these for me. I even used Arctic Silver 5 with it - close to the correct amount, mind you - and it's not going any lower than it was with the stock cooler that came with my processor.
Here are the rest of my specs:
Intel E8400 overclocked from 3.00 to 3.25Ghz
Asus P5Q motherboard
XFX Nvidia GTX 260
4GB G.SKILL DDR2 1066
SATA hard drive and optical drive
Do you think this problem would be solved by simply getting a new case? Despite how ugly and flashy it is, I might just have to get the Antec 900 because it seems so standard for a lot of people's builds. That, and my current case (The Centurion 5) really dissapoints me. Not only does it have crappy airflow, but it has this strange issue where my motherboard doesn't even align correctly with the rest of the case. I had to even use some special washers on one side of the mobo so it would lign up at perpendicular angle to the PCI card bays.
I'm just a high school student and I don't have a ton of money to spend, so it kind of hurts when I have to drop more money than I have already on this thing. But I am completely open to suggestions.
XFX Nvidia GTX 260
