My cooling & MBM5 question
Tullphan
I'm running a 2.6c w/stock cooling and a 9700Pro in an IS7 motherboard w/a 512mb kit of PC3500 HyperX inside a SLK3700AMB case w/stock 120mm fan in front hooked up to a rheostat & a 120mm L1A in the rear w/the grill cut out. It's powered w/an Antec 400w ps that's been modified w/a 80mm L1A.
My question is the temps and other settings on the dashboard. Presently it's at 42c cpu & 35c case with the processor at stock speeds. Core 0 is showing 1.5v & core 1 is @ 2.64v. Next to those is "+3.3 (3.25v), +5.00 (5.05v), +12.00 (12.04v), -12.00 (-6.84v), -5.00 (-3.58v). Can anyone explain that to me? Are those normal? High? Lo?
TIA!
I can tell you about the first two:
1.5v would be your vcore, the voltage going to your processor. This is a healthy voltage
2.64 would be your vdimm, the voltage going to your memory. This would be just fine for stock speeds too
I can't say much about the other numbers except that they are the values coming right off the rails of your psu.
hth
Yea your Vcore, Vdimm, 3.3, +5, and +12 all look fine.
Is your system stable? I was also concerned with my -12 and -5 rails. They are off even more than yours are, but my system is completely stable.
-5v and -12v don't work on these board/ simply set it to not show/ Core 1 is what your looking for, disable the other.
With Core 1 being.........??
(Sorry...new to MBM...the help notes didn't tell me what it was either)
