My chassis usb's are fickle
newtobuilding
23
Ok, so i was here a couple of months back to get advice on a build, which i have completed now. The only issue with it though, is that on occasion, my front two usb ports will refuse to work. For example, i was able to run a joystick on one, but not a portable hdd on the other, or a blackberry wouldn't charge. And now neither will work for my printer usb cable, which has a blue led to indicate if it's connected to my pc, which won't turn on with me Chassis usb ports. It works on my motherboard usb port though.
My chassis usb ports are 2.0, and the one which i tested it on the back is also a 2.0. any insight would be appreciated.
EDIT: i just realized this should be moved to computer help
lsv
1,610
It sounds like your internal USB connectors for the chassis ports have not been correctly attached. Maybe some prongs are in the wrong place. Can you verify that both internal cables are properly connected?
