My car makes funny noise at 70-85mph
WinkOsmosis
Banned
Sep 18, 2002
13,990
I haven't gone higher than 85.. Around 70, I hear a sound like tires make when rolling over rough road surfaces. Persists if I put the transmission in neutral, so I know it's not the engine/transmission. Any ideas? Could it be uneven tire wear, maybe a flat spot causing some kind of harmonic reinforcement?
1995 240sx
ThaGrandCow
7,956
I had the same problem with 2 separate cars in the past.
Get your tires balanced, possibly realigned. Problem should be solved.
isekii
28,578
it's probably just the tires tread patterns.
Some get unbearably louder after you put certain mileage on em. The best suggestion would be to put more sound dampener to eliminate the road noise.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Thanks. I think I'm due for a rotation so I'll get a balancing too.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Hm. My tires are Dunlop FM901s. They are designed to have low noise by having a varied thread pattern. The tread blocks appear to have varying, random sizes.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
A brief look at Dunlop's own website reveals that the FM901 receives 2 out of 4 "stars" for "Quiet Ride" and it is shown as a high-performace V- or Z-rated tire. That's not going to be a quiet tire any way you look at it.
ZV
WinkOsmosis
Banned
Sep 18, 2002
13,990
ZV
Yeah, but it definately wasn't making this noise before.
fredtam
5,694
Out of balance, uneven wear, or flat spots on the tires. Slam on the brakes recently?
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
How many miles are on them? Tires, in my experience at least, tend to start getting noisy about 25% into their treadlife and keep getting noisier.
ZV
WinkOsmosis
Banned
Sep 18, 2002
13,990
ZV
ZV
Hmm. About 11,000 miles IIRC.
TechnoKid
5,575
Get your rear diff fluid checked/changed out. You could do this yourself. Make sure you take out the fill plug before you try and take out the drain plug.
Even in neutral, the drive shaft still spins (and the gears in the diff), and low/old gear oil could cause noise.
However, with 11k on those tires, they could be worn already.
Krugger
820
yea, slow down... ;)
sorry, no one had said it yet, and you got good suggestions already.
