My Car Keeps Overheating
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Originally posted by: Eli
Originally posted by: bctbct
A quick google on 2004 vauxhall corsa sxi shows this is a common problem and the car should be let idle for 2 hrs and if the raditor overflows you have a problem.
I'm not sure exactly what the "problem" is.
I am: lack of logic and common sense. As you said, if it isn't moving, air isn't moving over the radiator. It'll heat up until it reaches the temperature where the fan finally kicks on. I wnoder if the OP would think it's okay to drain all the coolant and oil from the car and leave the engine idling for half an hour or so... after all, it's not driving, therefore all should be okay. :p
