My car is getting 23MPG average with city and highway driving
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
Originally posted by: fbrdphreak
Originally posted by: Nebor
Originally posted by: fuzzybabybunny
Why would the engine be using gas if the wheels are spinning the engine? When your car is in motion and in gear and coasting your wheels are turning and thus your engine. Car manufacturors (or at least some) program the throttle to completely shut off at this point, because there's no point in it since the engine is turning... by itself.... there's no need to use gas to keep it spinning.
Likewise, when you're coasting in neutral, your throttle has to kick in and use gas because it needs to keep the engine spinning at its idle RPM.
I take it you've never driven a car with a tachometer to verify your theory?
Because it's laughable.
Depending on the vehicle, it uses less/no gas coasting (depending on RPM) than it does when in neutral @ idle. This was discussed rather thoroughly in another thread on here, if you care search for posts by Zenmervolt.
Right. If it's coasting in 5th gear at 10mph at 500rpm, then Nebor is right. But as long as the RPM is above idle you'll see benefits.
dxkj
11,772
Originally posted by: michaels
I read an article saying that the government was gonna force auto makers to start putting accurate mpg estimates on new cars. Supposedly the numbers are off by 205 on all vehicles.
I read an article that said the EPA or somesuch entity is the one who tested and rated mPG on cars, not the auto makers
zephyrprime
7,512
With that big of a deviation, there's probably something a lot more significant wrong with it than underinflated tires or a dirty air filter.
You may be getting blow by or your o2 sersor is busted or your mass airflow sensor may be screwed. The fact that you get the same mileage in highway and city driving is especially suspicious.
Mayfriday0529
7,187
I think my car eats to much gas. But maybe not. I have a 2002 Nissan Sentra with 94,000 miles. I been watching how much miles i get with a fuel tank. I have gotten about 310-320 miles before I had to refill it. Its suppose to hold 13.20 gallons. So i'm getting about 25 miles per gallon.
Do you think 25 is good? I travel 63 miles a day.
CrackRabbit
16,642
62
The EPA is the one doing the testing, but the tests that are being used were created in the 70s, they measure the fuel usage at 55mph with no a/c turned on on a simulated flat road. It is very easy to get great gas milage in those conditions, thats why the numbers for almost all makers and models tend to be inflated.
mayonnaise
391
Originally posted by: fLum0x
dont floor it every time you go somewhere, dont hold down the gas when you see a red light up ahead...just coast, put the windows down. all three of those should help you. The first one is more or less driving casually and with a cruise as much as you can.
Do NOT put the windows down. It kills your aerodynamics and the airflow etc etc. It was proven on The Mythbusters. Windows up = better MPG.
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
Wasn't it for only a certain speed and above though? Like windows up for highway. For cruising around town it really doesn't matter?
fbrdphreak
17,555
Don't go by the size of your tank, go by how much you put in the tank. Its a little closer, but still just an estimate at best.
fbrdphreak
17,555
Yeah around town windows don't do jack
Ika
14,264
It's still more fuel-efficient than running AC, though. But windows up + AC off is best!
letdown427
1,594
@fuzzybabybunny: I agree 100% about the coasting in gear. It's true what you've said. They even formally announced it in the news on Top Gear a while ago! :p
But yeh, it's true. If you have an instantaneous mpg reading (or even one that does an average, just reset it and it's as good as instantaneous for a while)
Coast along in neutral (let's say downhill, to help keep you going) and it'll eventually max out somewhere (it may be off the scale, if so, use the range left reading, as that'll go up into thousands)
Now, put it into a high gear (so that engine friction isn't going to sloow you down to quickly) you'll notice that the mpg suddenly increases again (or range goes up again, depending on what you're looking at).
It works, I've done it in my car.
If you want more mpg, you don't necessarily have to drive slowly, just drive as smoothly as possible. For example:
Acceleration is the biggest killer for mpg. So, once you get to your cruising speed, try to stay up there. If there's people in front, follow them from further back. That way, you can just lift off when they start to slow down, and engine brake, which will use little gas, and also, typically, they'll start to speed up again, and you won't have to brake at all.
Take corners properly (if it's safe to do so) to try to maintain your cruising speed (say 60mph). By not constantly accelerating and braking, you're going to use a lot less fuel.
Take that massive amplifier/cabinet/corpse from the boot (trunk) that you haven't been bothered to take out.
Close the windows. I'm also not sure about AC, I think it does have a reasonably noticeable effect though.
If you want to get serious about it, lose some weight. Take out the spare wheel and buy a can of that temporary 'get you home' foam stuff.
Hope that helps. My crappy 1.2 Clio gets me 45mpg ish with daily 54mile roundtrip to work. If I make sure I drive a bit slower and don't accelerate as harshly, it'll hold it's nose above 50mpg, but that does get a bit boring, and means I have to get up earlier...
Here
Point 25 on there also has this note:
NOTE: If you own a car with fuel injection, it is more efficient to keep the car in a high gear while going down hills. Fuel injected cars will shut off fuel flow to the injectors when coasting downhill in gear, as opposed to consuming fuel to keep the engine at idle while in neutral. Simply take your foot off the gas
BD2003
Coasting in gear means you use ZERO gas during that amount of time.
As long as the engine is running and the ignition is on, you car is using gas. It doesn't matter if you're coasting in gear or idle or anything.
Lower RPM at closed throttle ie coasting in neutral = less gas than higher RPM at closed throttle in gear...
His laughable theory is correct.
EyeMWing
Banned
Jun 13, 2003
15,670
That's funny, because it's the GOVERNMENT that MAKES the numbers and forces them to be placed on the vehicles.
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Sorry, but very little is "proven" on mythbusters. It's a show for entertainment. Also, at lower speeds, air resistance is all but negligible. (Make a giant cardboard car, run down the street with it. A little air resistance. Now, push the car. See how much harder it is to push the car.) Compare the air resistance to the resistance of pushing the car.
Eli
Super Moderator | Elite Member
8
False, if the engine is turning more RPMs than the throttle position indicates, the injectors stop pumping.
iversonyin
3,303
I think some government agency did a test to this. At higher speed, wind drag does make a difference in car mileage. But I think for smaller car, A/C uses more gas than the lose of mileage cause by wind drag
dawks
Just a quick note, United States MPG are different the the MPG ratings everywhere else, since the US uses their own Imperial Gallon.
Pepsi90919
Originally posted by: foghorn67
if it takes you more then the standard few cranks to get the engine started once in a while, you need a fuel injection cleaning, and a mass air flow sensor cleaning.
on the highway, use the a/c. It won't hurt any.
what does a MAF have to do with starting? and why would the detergents found in all gasoline not be enough to clean fuel injectors? why did you not recommend checking ignition or the air filter in that situation?
Pepsi90919
what do you mean laughable? he's absolutely right, the fuel delivery shuts off.
ElFenix
102,354
8,444
the US does not use imperial gallons.
BigToque
11,700
I just checked again after refueling my car...
In the city I'm getting 28 mpg.
On the highway, I'm getting 25 mpg.
I think it's a little strange that I'm getting worse milage on the highway than in the city.
feelingshorter
2,439
Buy a civic.
Eli
8
That is very strange.
What methods are you using to check your MPG?
