My C drive is running low but my D drive is almost empty
faye
2,109
Hi, my C drive is running low, less than 1GB... but my D drive and E drive and F drive are all more than 30 GB
all the drives have data... can i "somehow" transfer harddrive space from one drive to another?
using XP pro.
WD800JB
boyRacer
18,569
Never failed on me... :) You can even ask other people on here... just a couple of clicks... a reboot... and your partitions are resized. :D But of course don't blame me if something goes :confused: ;)
WarSong
1,147
Partition Magic is a great utility. Make sure to back up anything you value though before doing anything.
corkyg
Elite Member | Peripherals
27,370
240
Just got the new PartitionMagic 8.0. It works very well, and can now handle external Firewire drives as well as drives up to 160 GB. I have used it since version 3 - never had a problem with it. Backup? Well, . . . I am always 100% backed up on a duplicate drive. Makes for a relaxed attitude towards betaware and new stuff. :)
Athlex
1,258
A while back I remember using a program called partition commander. Basically a partition magic knockoff, but it worked just as well and cost about half as much. Don't know if there's a current version, but it might also be worth a look.
