- Apr 27, 2000
- 22,479
- 12,339
- 136
**DISCLAMER: This post is not a specific endorsement of any particular product or manufacturer/reseller. I just used parts that I felt would work well within my budgetary constraints given what I wanted the system to do. Feel free to use whatever works well for you. Investigating products from Anandtech's various advertisers is strongly encouraged**
The upgrade bug bit me a few months back, so I've been looking for excuses to buy new hardware and tinker with it. Here's what I bought:
Case: Coolermaster Centurion 5
PSU: Corsair HX520
Motherboard: Abit NF-M2 nView
CPU: AMD Athlon X2-3600+ (Brisbane) OEM
RAM: OCZ PC2-6400 Platinum DFI Special (2x1gb)
HSF: Thermaltake Big Typhoon VX
HDD: Seagate 7200.10 250gb (16 mb cache) OEM
DVD burner: NEC AD-7170A OEM
Extra fan: Silverstone FM-121
Thermal Paste 1: Arctic Silver Ceramique (ordered AS5, got Ceramique)
Thermal Paste 2: Shin-Etsu X23-7783D
Plus some zip ties, zip tie mounts, electric tape, duct tape, a piece of window glass, 200/400/600 grit silicon carbide wet/dry sandpaper, two Sharpies, and . . . well that's about it I guess.
Q: No video card?
A: Yes, no video card. That might come later, but for now I'm using the motherboard's onboard video.
Q: No sound card?
A: uh, yeah.
The result is: a working computer! I even filmed the whole ordeal and spliced together a building guide aimed an newbies that might be a bit intimidated by the idea of building a PC or haven't otherwise seen one built before. It's far from comprehensive, but it covers most of the important bases, again minus a video card because, hey, I didn't really need one. Much. Yet. Here's the video. If you like it or think it might help somebody out, feel free to tell others about it. A few build notes:
1). Cable management (or lack thereof):
I went into the build process armed with zip ties, zip tie mounts, and even electrical tape thinking I could engage in some fancy cable management. Then I realized that the case had so few holes in the motherboard tray and elsewhere in the case that it would have been very difficult for me to do anything fancy like this. What I did instead was move most of the few power cables I did need to use into the empty 5 1/4" drive bays where air didn't need to move (in this setup anyway) and restrict some other cables from falling into fans or otherwise interrupting airflow with zipties. It worked out very well. Airflow in the case is good.
2). Why I chose what I chose:
Coolermaster Centurion 5: I knew I wanted a case with a side air duct/fan/hole/vent/etc. so I could use the Big Typhoon (in this case, VX) with a Silverstone FM-121 mounted on it and get unrestricted airflow for the CPU without having to buy a high-airflow case like the Antec 900. At around $55, the price was right and it fit the bill. The Big Typhoon gets all the cool air it wants and keeps most of the motherboard cool as well.
Corsair HX520: 80% efficiency, solid dual 12v rails, reliable components, and modular cables. Yeah, that works for me. It leaves plenty of room for upgrades including a single g80/r600 video card.
Abit NF-M2 nView: Okay, so it's AM2. See the next entry on why I went AM2. That aside, I had it down to two boards: this one or the DFI NF UltraII-M2. The Abit board was cheaper and had onboard video so I could get it and avoid buying a $20-$40 el-cheapo vid card that I would openly resent. I do sort of miss having the OC options of the DFI board, though, but I'll live.
AMD Athlon X2-3600+ Brisbane: Several reasons. First off, I've been curious about the impact of the DDR2 memory controller on AM2 chips for awhile, but nobody has really done a lot of memory benching here on Anandtech with the AM2 platform (that I've noticed). Secondly, I like an underdog. Thirdly, I arrogantly believed that I could beat the 3.1 ghz wall so many other people hit by using a combination of good thermal paste, good HSF/fan combo, and lapping. Fourthly, I wanted to see how well X2s scale vs Core 2 chips at high clock speeds (based on this benchmark and testing I hope to complete on my own, see the overclocking post below). Fifthly, the price was right. ~$100 for an X2? Sweet. EDIT: now $55 for an X2? Unbelievable.
OCZ PC2-6400 Platinum DFI Special: The kit works well, the board supports its upper vdimm limit of 2.4v, and it was $160 after mail-in rebate. This should give me plenty of wiggle-room when testing the Brisbane's memory controller and its effects on scaling.
Thermaltake Big Typhoon VX: I've seen at least one benchmark where the Big Typhoon dominates provided it has a 100+ cfm fan. The VX ships with an 86.5 cfm fan, but I unmounted that and used it as the exhaust fan for the Centurion 5. I kind of wish I had gone with the new Ultra 120+ instead, but it's not even out yet, and I doubt it would cool the motherboard components as well as the Big Typhoon does. Plus, the VX was not that expensive. I had to get the VX to be sure I got the right mounting mechanism for AM2 as well.
Seagate 7200.10 250gb (16 mb cache): It's the cheapest 7200.10 drive with 16 mb cache. Given the fact that the 320gb 7200.10 handily defeats the 750gb 7200.10 performance-wise, I figured I'd try out the 250 gb drive and see if it was as good as the 320 gb one. So far, so good, but I haven't done any testing.
NEC AD-7170A: Eh, it works. I liked my 3520A so I figured I'd give NEC's latest a whirl. This isn't just an NEC drive, it's a Sony NEC Optiarc drive. It seems okay to me.
Silverstone FM-121: After removing the VX's included 86.5 cfm fan and using it as the case exhaust fan, I strapped this 110cfm beauty onto the Big Typhoon for extra cooling action. Since it's only a 120x120x25mm fan (vs 38mm), it mounts with ease.
Arctic Silver Ceramique: Originally I ordered AS5 with my Big Typhoon VX as a knee-jerk reaction. Then I did some reading and found out that Shin-Etsu x23 kicks its butt all over the place. So I 2-day shipped some X23 so it would get here at the same time as the last of my parts. When my last shipment came in, I discovered that the shipper sent me AS Ceramique instead of AS5. Interesting, but hardly noteworthy since I wound up using X23 instead.
Shin-Etsu X23-7783D: As mentioned above, this stuff rules, especially on lapped surfaces. And I was gonna lap, so I got some. It's hard to find, but if you Google search long enough (or just read the thread I linked above) you can find it. 7783D is the latest variant.
3). Build quirks:
Case faceplate: For some reason, odd plastic bits jut out in the 5 1/4" drive slots preventing your CD/DVD drive or other 5 1/4" drives from sticking all the way out to be flush with the faceplate. I think. Maybe there's something I'm missing here? Anyway, right now, my NEC drive is about 1-2" recessed into the machine, though the tray still opens without difficulty. It works fine, it just looks weird.
Narrow 3 1/2" drive bay: Dunno why, but the harddrive cage is almost too narrow. It scratched up the sides of my Seagate drive. The locking mechanism doesn't seem to work properly either, or at least, not terribly well. Still, the drive doesn't slide around because the bay is so narrow. Very snug fit.
Bizarre temp displays: The NF-M2 nView and Brisbane together produce wild and crazy CPU temperature readings. The motherboard temp sensor reports temps around 30C too high at least, and there's no telling if it moves upward in temperature properly when the CPU is at load. Core Temp, on the other hand, reports impossibly low core temperatures. All the other sensors on the board seem to be working very well. The only way I have to check CPU temperature right now is to put my hand on the base of the heatsink, check the sides for heat leaking out from the socket, and uh, guess. Things seem to be pretty cool right now.
Cranky CPU fan header: The FM-121 could not draw power when connected to the 3-pin CPU fan header on the motherboard. The motherboard also complained audibly that I had no CPU fan installed when I did (even though it would not power up). The first 30 seconds this CPU spent in operation were without a fan blowing on it at all save the exhaust fan which was only pulling air at 1200 rpm at the time (low setting). I had to connect the FM-121 to a 4-pin molex and deactivate the CPU fan alarm in the BIOS to avoid obnoxious alarm beeps.
And . . . that's all! Hope you enjoyed the video. The next two posts will have lapping and overclocking information.
PSU: Corsair HX520
Q: No video card?
Q: No sound card?
A: uh, yeah.
3). Build quirks:
