My Asus P4C800E- deluxe won't work wit prescott cpu, help
Esmegma
10
Hi
This is strange but mt board won't boot the 2.8 prescott cpu. Ireturned to the store and i did work on a springdale asus mobo. I've got the last bios update 1016, and still nothing, nada... it just won't boot!!
I need your advice guys ... should i rma the mobo or what?
Any ideas woul be apreciatted.
cheers
Big Lar
6,330
Try the 1015 bios, should help you out a bit. Make sure you have a decent supply as well, and what revision is the board? This info can be found inbetween the pci slots.
