ohmygosh
I have written this so many times that I am now cut and pasting...
look, first of all I have the EXACT same setup and I have no problems.
IF you have already reformatted and reinstalled the 6.26 drivers OR ABOVE NOT THE 6.18s!!!
DONT LISTEN TO THE MORONS THAT ARE SAYING THAT THE 6.18s ARE GOOD DRIVERS!
THEN, make sure and install the 4 in 1 v. 4.25 drivers (
www.viahardware.com) drivers are in the lower left corner
1. install the USB filter 1st
2. install the AGP driver (make note of where it keeps the viagart. file)
3. IMPORTANT - then and only then install the 4in1s ... it may ask you on boot up for the viagart file - browse to the location.
4. Install DX7a
5. after all this install the 6.2x or 6.3x drivers from nVidia
get that bios revision off. go back to the 1004a
If you are still having probs, hopefully you bought that mobo somewhere that you can return it. There are a few known issues out there and I had to return 2 A7Vs before I got one that was stable.
My system has been running with no crashes for almost a month, and at this point I think that everything is fine.
ALSO!!!
The memory cannot be overlooked!
Hopefully, you have some decent memory. If not, that is probably your problem. I would seriously consider investing in some High quality memory. NO one hates this fact more than I do, but cheaper generic memory + AMD durons, tbirds and athlons DO NOT MIX.
good luck!
