My AOpen AX4C MAX Canterwood Setup is giving me headaches.
My setup is as follows:
Intel P4 2.4B
AOpen AX4C MAX
Corsair 1024MB TWINX3200LL (As two modules of course!)
ASUS Geforce4 Ti-4400
Creative SB Audigy 2
Western Digital JB8000
Antec TruePower 430W
My HDD is connected to the primary IDE connected and both my optical drives are connected to the second IDE header.
I'm running Corsair TWINX3200LL modules and I THINK this is what is causing the troubles. I'm NOT running them by SPD.
At the moment with my DAMN expensive memory I am running 2.5-4-4-8. If I drop the timings any lower I crash. I have the DIMM voltage reasonably high as well, so voltage isn't the issue here.
I am also running the latest AOpen BIOS - 103.
The strange thing is this:
I have memtest86 as a bootable CD. Upon running memtest86 I can have the memory timings set all the way down to 2-2-2-6 and not run into any problems (I am only running the first 7 tests). So of course I can run 2-3-3-6 as well. If I try either of these timings and attempt to boot into Windows XP, I crash every time.
If I try to overclock my CPU with this board Windows XP hates that as well and crashes (if I can even get into it). Even just from 133 to 150 will cause instability. Could this be tied to the ram?
Any thoughts on what I can do to find the real problem here?
Is it hardware or Software that is causing the problems?
Any help would be Brilliant.
Thanks,
Mark
Intel P4 2.4B
AOpen AX4C MAX
Thanks,
Mark
