I assembled a computer about a week ago with all brand new parts. The setup info is below. The power supply I chose was the Antec TruePower 430 Watt psu, which I purchased after reading dozens of great reviews, ratings, and forums posts about it. I assembled and installed everything and set up Windows XP on it and installed all the basic drivers and software and everything ran just fine for a week. I also had the system hooked up to a surge protector and a Belkin 800VA UPS, so the power my computer was getting was very clean and controlled. I was not overclocking any components. I checked the BIOS and some xp diagnostic programs and there was no voltage drop in the power supply. The whole system looked like it was in perfect working order...
Then this morning, during a routine reboot, the Antec True430 PSU suddenly made this LOUD noise that sorta sounded like a terrible scratching / buzzing sound, and the power supply started smoking and giving off little bits of sparks. I dove for the power cord and unplugged the computer. After my pulse returned, I tried to see if any of the connections were loose and if any power cords were out of place. Everything inside the case looked fine except for the smoking psu...
I'm scared as hell now. I already filled out an RMA on the power supply. And it's a hassle not to have a working computer for a while, but that's not my main concern. I'm worried sick that the power supply could have damaged my other expensive components when it blew. This is supposed to be one of the best power supplies on the market, and 430 watts should have been more than enough for my system. I guess I was just very unlucky and got a defective unit. I'm wondering whether I should replace it with the same psu or go for something else (I had the Vantec VAN-520A in mind - more expensive but with more power and also very good reviews).
I could really use any kind of advice, stories of similar experiences, ideas, suggestions, whatever. Thanks in advance guys. I might run to a local store tomorrow and buy a psu just to see if the rest of my system got damaged. I'm gonna cry if my power supply fried something else... Meanwhile, I'm biting my nails and posting on the forums for ideas using someone else's computer... sigh...
Setup:
Belkin 800VA 450 watts UPS
Antec TruePower 430 watts psu
Asus P4PE mobo /w GBLan/Sata/Raid
P4 2.53 Ghz
Corsair XMS PC3200 C2 512 Mb DDR RAM
ATI Radeon 9700 Pro
2x Western Digital SE 80 Gb HD in RAID 0 setup
IBM Deskstar 60 gig (backup reasons)
NEC Floppy drive
Lite-On 40x CD burner
Lite-On 16x DVD drive
Creative Audigy 2 Platinum
5x 80mm quiet case fans
Setup:
P4 2.53 Ghz
ATI Radeon 9700 Pro
NEC Floppy drive
