THis happened on friday. During the day i noticed my side casefan turning on and off (it was connected to the fan only connectors on the PSU). I thought nothing of this, and figured it was the fan dying.
I left the computer for a 2-3 hours and when i came back upstairs to it, i noticed it was turned off! The LED by the power switch was blinking, but i could not boot up the system. All i got was maybe power for a fraction of a second, only enough to slightly rotate the fans. I then checked all the other computers and clocks upstairs, all the clocks were still ont he correct time and the other two computers upstairs were working fine. Also, my computer was plugged into a 50dollar APC surge protector power strip.
I took off the side panel and i noticed a slight burning smell. Not terribly strong, but noticible. The PSU grills smelled particularly strong. I then took the truepower430 out of the case and plugged it into an old gateway 333mhz p2 (bought back in feb 98), suprisingly the system booted. I figured this old computer wasnt stressing the PSU enough, and even though it died, it still had enough power to run this old machine.
I figured my PSU was toast and i went to compUSA to get a quick replacement ( i bought the antec neopower480). One of the fellows at the place tested my PSU and confirmed it was faulty. He used some device to plug into the connectors to measure voltage output. Im assuming one of the rails, maybe the 4-pin 12v rail that plugs in near the CPU (this isnt needed for the gateway), was outputting well below spec.
I brought home the neopower480 and the SAME thing happens, i only get the PSU to turn on for about 1/5 of a second. I then tried a number of things such as:
1) resetting the comos
2) uplugging everything from themotherboard except power switch connector, the 2 motherboard power connections, and the CPU.
in all cases i get the same damned thing: power on for a fraction of a second.
So i have concluded my motherboard was toast and i tested my Radeon9800pro, audigy2zs, and PCI tv tuner in another computer, and they all appear to be working. I cannot test my two SATA raptor drives, my athlon 64 3400+, or my 1gig corsair ram because i dont have any other compatible systems. What are the chances that these are fried given the circumstances?
I just ordered a new motherboard http://www.newegg.com/Product/Product.asp?Item=N82E16813131498
