My Antec Smart Power PSU fan isnt working!
angrymonkey
17
This is my first build and I just got finished hooking everything up. I turn on my computer and everything works normal but to my suprise the psu fan isnt working. I tried plugging the three pin fan plug into both of the availible fan connectors on my mobo but the fan still wont turn on. What should I do?
Im using a Chaintech VNF4/Ultra mobo in the Antec sonata II with the 450 watt Smart Power PSU
JBDan
2,333
If I'm not mistaken, the outer fan on those psu's does not cut on till the psu reaches a certain temp. The inner fan should be on...open her up and see.
angrymonkey
17
Where did you find out this information about the psu anyway?
Edit: Never mind, the inside fan is running, thanks
JBDan
2,333
I read it somewhere cant remember....think it was SPCR...oh well glad you got it :)
JEDIYoda
33,986
3,321
Do people actually buy these things without havinga clue how they are suppose to work??? hmmmm
thescreensavers
9,916
Ok, I have the Smart Power series PSU the outer fan does not kick in till a certain internal PSU temp or as for me it goes on only when I play games like UT2004 and other games or Heavy CPU/Graphics usage it will turn on. But I smelled a burning smell first but then it went away so I think it was just a new smell like a new car smell because I have heard other ppl say the same.
