My AnandTech Rig issues
MrK6
Yah, everytime I try to enter my rig's info it doesn't let me. I'm obviously logged in and all cause I'm posting this message, help?
I justed added a rig to my account with no issues. Being logged in here does not mean that you're in there. To edit your system rigs in "My AnandTech" requires that you login there. 🙂
I am able to edit it. It's just when you're all done filling out all the fields it just gives you an error and says webmaster has been notified. I suppose it wouldn't let me get to adding a rig if i wasn't logged in, would it?
Originally posted by: IvanAndreevich
So, as long as you don't fill out the CPU overclock speed, it will work fine?
I don't know about that, but I do know that when I try to enter a speed in the CPU Overclock field of any of my existing rigs, that the setting is not retained.
ProviaFan
It's not retained or it gives you an error and doesn't save @ all?
It's not retained at all for me. Look at the first link in my sig, it won't keep the 3600MHz overclock speed on my CPU.
Just checked. As long as you DO NOT ENTER CPU OVERCLOCK SPEED it works fine.
Which is exactly the problem. Everything else sticks except the OC speed.
Originally posted by: ProviaFan
Originally posted by: MDE
Originally posted by: oldfart
CPU overclock speed doesn't work for me.
Same here.
Just noticed that myself. 😕
That's actually not been working for months.
Either that or it stopped working again, but last time i tried to put an OC speed, it didn't work, & that was a few months ago.
I found the only way I was able to add my laptop was to make sure EVERY mandatory field was filled in before submitting it.
I know this thread is fairly old, but I found out that by only filling out mandatory fields and leaving all other blanks empty, I can finally create a new rig. I think I can successfully edit afterwards, but I've only tried with the comments field so far. Well, bump to some kind of solution.
