My 9800Pro BBA heatsink seems loose, how is yours?
Johnbear007
I got mine retail from bestbuy, and the heatsink is a bit loose. I want to know if this is common of if mine is mesed up, could someone check there BUILT BY ATI 9800 pro? it has a silver heatsink on it
thanks!
more like I can slightly TWIST it, although if I give it a soft tug it feels like its pulling something up.
Im not terribly concerned, I can exchange it, but if they are all like this I dont want to bother.
i don't think i can twist mine... but i can just slightly rock it from the pins holding it down... i guess that would be the same as pulling it up. i'm sure it's ok though.
You cant twist yours at all? Hmm ill play with it again later and decide.
Thanks a bunch for checking yours. I apprecate it!
