I just installed a new powersupply, antec smart power 350 watt.
When i boot up i got an error msg to go to the hardware monitor in the bios.
the readings under the -5v is -6.19 in red. whats going on? is it safe to ignore?
<a target=_blank class=ftalternatingbarlinklarge href="http://www.antec.com/us/support_productInfo_details.php?ProdID=26350">Q: Why am I getting an error for the -5v rail?
A: The -5v rail has been removed from the Intel Standard and is no longer needed.</a>
