- Jul 9, 2000
- 11
- 0
- 0
Hey all,
My bro and I each put together a 1ghz Thunderbird system. Specs: 256 pc-133, ibm deskstar, Geforce 2 etc...
We bought a case from www.colorcase.com. Here is a url to the type of case we bought:
http://www.colorcase.com/products/case/translucent/rainbow.html
We both got a black case with a 250 watt Fortune power supply.
Alrighty, we installed all the compentents once we had them all shipped to us and we were off and running... installing Windows and drivers.
Though we both started to experience A LOT of lock ups. A hard reboot was the only way to get the system up again. After a lot of frustration we both think its that these cpus are running way to hot. I obviously don't have much experience with cooling a system and I really didn't plan properly for it.
We just have 1 80mm fan in the front of each case and the power supply blowing out from the back. The Leadtek Geforece 2 has its own fan.
Here are the temp readings I am getting from the Bios.
Current CPU Temp ranges from 39-55C. Around the 40C mark our systems really start to lock up a lot. Current System Temp is around 37-33C.
From what I have read this is pretty hot. Is this true? I don't even know what temp is advised for a 1GHZ TB.
What do you experts advice my bro and I do? We each have a new system that we really can't even use. Do you think this is what is causing the constant lock-ups on our systems?
The lock ups are happening from all different angles, using my cdrw, coping files, playing games, listening to mp3s etc.. I have defraged, ran all of Nortan systemworks programs and they all say everything is clean and good to go.
Also can someone please advice us on what action we can take to get these cpus/systems cool enough to run all day in our room with the hot Las Vegas summers. What is the best cpu cooler we can get for our Slot A cpus. Btw, we both have a Iwill KK-266 Motherboard.
On to the next question. We each have one stick of 256 Micron pc-133 ram.
Now when I power up my machine, the intial read sequence on the right hand side reads DRAM = 100mhz. Isn't that supposed to read 133mhz? How can I changed it to 133? Or am I reading this wrong.
Alrighty, so please everyone advise us if these temp for the cpu and system are to hot and if so, what type of cpu/system fans can we install on SLOT A cpu. I need your expert advice as we are both are pretty ingnorant on the issue of cooling a system properly!
Any urls and detailed info would rock!
Thanks for your time and help!
Justin
Justin
