<<<>>>My 12 T-bred results<<<>>> *5/9/03*
Shimmishim
7,504
save the 35 bucks :)
i don't think the performance difference between a 2.1 ghz cpu and 2.2 ghz cpu is huge...
'look mom, i can load windows a whole .02 seconds faster!!!'
majewski9
2,060
Hmm thanks a lot man that was very helpful! I think I might even reconsider getting a TBred 1700+. Is that J stepping available @ newegg?
Shimmishim
7,504
yes
however, newegg isn't guaranteeing 'b's though...
you might have to get it from excaliber if you want a guaranteed B
the only 1700+ b i got from newegg turned out to be a 0251 jiuCb (c's aren't as good as H's)
bgeh
2,946
Originally posted by: Shimmishim
if i decide to get another one.... :)
you gotta be kidding..........i'm just ready to get one(for a friend) and you are on no.7............:confused:
anyways, if you get a new one, then good luck(get a new week, like week 8-10):D:D:D
Shimmishim
7,504
Originally posted by: Tabb
Interesting. So with a 1700+ can you hit 2Ghz and 166Mhz for sure?
most JIUHB's are hitting over 2.0 ghz. They are topping out around 2.1 to 2.2 ghz... not bad from the stock 1.47
Tab
12,145
I hope your right, as I will be purchasing one soon! Too bad newegg doesnt carry JIUHB's or eXcaliberPC Carry Epox's 8RDA+ :(
XBoxLPU
4,249
Just order the cpu from ex and the 8rda + from newegg like I Did :)
alchemize
11,486
I'll be getting my JIUHB 0304 and HyperX PC3000 today from Excaliberpc :) Will post the results in the next day or two...
I'm on an A78NX deluxe however, might not quite Shimmishim it :)
sygyzy
14,001
4
Kingston HyperX PC3000 Memory, 2x 256MB
AMD Athlon XP Thoroughbred B 1700+
Epox 8RDA+ Retail
What do you get when you add these together? A FF bios effed up error and an RMA to New Egg. DAMNIT!
alchemize
11,486
Here's my results so far:
166x11 OK
182 x 11 No Post
175 x 11 No Post
166 x 12 OK
166 x 12.5 OK
170 x 11 No Post (tried several voltages, very relaxed timings)
168 x 10.5 OK
170 x 10 No post
:( This is HyperX PC3000, 2x256. Edit: I'm doing something wrong. When I set SDRAM CAS Latency to Auto, it works at higher speeds (posts anyhow) I must be showing my ignorance :) I'll keep tinkering.
Shimmishim
7,504
up your vcore and your vdimm (no more than 2.77)
try 11 x 185 (2-3-3-7) ....
and see if that works...
Shimmishim
7,504
Epox 8RDA+ Retail
sorry to hear that :(
you tried everything? tried only 1 stick of memory in dimm slot 1 or dimm slot 3?
default settings? 11 x 133?
sygyzy
14,001
4
Yup, tried everything including what you just said. It's on it's way back. I hope I get the replacement soon.
alchemize
11,486
I'm not sure what I fixed, other than setting the ram to manual and 2-3-3-7.
185 x 12 (2220) 2-3-3-7, running Prime95 but it is late :) gonna start some serious tweaking tomorrow ...
Shimmishim
7,504
good luck to you...
be sure to do what i said in the PM.... it might help
on that note.. my pc3200 ram is coming in today... i dunno if anyone has been following the hot deal forum but ebay has a reseller selling winbond memory for dirt cheap... hopefully it'll be here today to see 2 things:
1. if my ram is limited by the mobo (vdd voltage)
2. if it's my hyperX ram that won't let me hit 200 mhz
okay
later! - time for class :(
alchemize
11,486
OK Shimm I'm finding the sweet spot. As I said in the other thread, I think I was going for FSB first and CPU speed second. Now that I've reversed course, my last 5 minute prime95 passed at 177x12.5 (2215), once I upped it to 1.75Volts, 2-3-3-7. Time to reel it in now :) I don't think I can get much more FSB but I'm sure I can get better timings...gonna try 179-180 @ 1.8 though...
