My 1.1Gb Celeron won?t post
FlashG
My old 566 Celeron runs great but I thought that a 1.1 Celeron (128 memory) would be a cheap upgrade. I installed the latest ASUS P3B-4 BIOS (ACPI BIOS 1008 beta 04) and fooled with all of the Slotkits settings (from default to 1.85v). So far it won?t even post. I think that 512 of new PC-133 might work but I want your opinions.
ASUS P3B-F board with latest BIOS
ASUS Slotkit
WindowsXP Pro
(2) Sticks of cheap PC-100 128 memory (256 total)
WD 40Gb HD 7,200RPM
New 40-12-40A Plextor Burner
New MX-420 GeForce 4 InnoVision
Sound Blaster Live Value
New memory (Yes - No - Else)?
No it wouldn't work at any voltage from 1.5 to 1.85 (1.75 is default). I was afraid to go over 1.85.
I also tried different voltage combinations of CU vs Celeron with no joy.
Other than new PC-133 memory I don't know what else to do.
Ah....that's a BIOS bug that ASUS refuses to fix (and it's been 3 revisions since the bug was found).
All of the BIOSes for the entire P2B/P3B family of boards will not allow 100MHz FSB with multipliers above 10. Change the FSB to see if you can get the thing to work, ie try 75MHz.
"LeoMael,
What if the celeron is a Tualatin core? Would that even work in that board?"
My cpu has 128 of memory and from what I understand it should (could) work. I think the Tualatin has 256 memory among other things.
