Just got my muvo^2 and having a problem with it. It wont turn on/work. It worked when i first got it (low battery though)
Left the charger behind, and plugged it in via usb. In the manual it says it can charge via USB. It has 2 important notes:
1) do not charge your players battery via usb port until you have installed software
well thats weird, but i did it anyways, though i DIDNT reset the computer. why do you think this is?
2) plug in the muvo (i did this - it was detected) and then unplug it via windows to beging the charging.
I did this as well.
left it plugged in for 3 hrs, now it wont turn on
thanks alot guys!
I did this as well.
thanks alot guys!
