Muskin PC3200 LevelII Won't Overclock! HELP!
Tyl3n0L
20
Ok, I have 2x512MB of Muskin PC 3200 Level II BH-5.
But the ram won't overclock for "/$%?&*( ... Previously with my 2x512mb of OCZ PC 3200Rev2 I managed to hit 230FSB @ 2.5-3-3-6, 2.8V stable on my Athlon64 3200+, AsusK8V, Asus ATI 9800XT...
The default timing on my Muskin are 2-2-2-6. I Slacked them to 2.5-3-3-6, 2.8v and tried 220FSB... The computer start-up but at the Windows Log-in screen it shutdown. So I tried 2.5-3-3-11, Same result. I also tried with 1 stick of it. Same problem. The max I can get out of it is 210fsb 2-2-2-6 @ 2.8v
I think it's because the muskin need more voltage. but 2.8v is the highest setting in the bios....
What do you guys think?
Thanks
MichaelZ
871
higher ram speed running loose timings roughly equals out to lower ram speed running tighter timings. if you have to OC the ram just to get 1:1 then you could try 3-3-3-11
