- Jan 3, 2001
- 41,920
- 2,161
- 126
I'm finally getting around to learning how to use my Tascam 8 track recorder, but I'm having trouble getting accurate sounds.
I'm using a condenser mic, and having a problem capturing mids. I've tried using EQ to compensate, but the signal is just not there. Right now I'm using a Shure SM57 clone miced to a 15w amp. Would there be a better mic choice?
Here's an example. I did all 3 guitar parts to this song, and added a premade bass/drum/vocal track.
Rock and Roll
This mic seems to capture acoustic guitar perfectly, but not so much electric. The main guitar riff sounds flat to me, and it's not the way it sounds coming out of the amp. Is there a better mic to use to capture mids?
EDIT:
OK, I took a lot of advice in here, and some other tips from some other sources, bought a REAL Shure SM57, and am getting much better results. It sounds half way listenable now:
Rock and Roll - Take 'leventy hundred.
Tips that helped:
-play cleaner with less gain/drive, more volume
-place mic away to the side of the speaker cone
-move the mic away so the sound can breathe a bit
-don't use a condenser mic to record guitar
Rock and Roll
EDIT:
Tips that helped:
