First, yes I know this is more topically relevant to the A/V & Home Theater section, but I think I'll get more regular-person responses and thoughts here in OT, so here goes :
I've been used to regular MP3s and AAC (iTunes store stuff) for quite a long time, and I never thought much about it. The quality seemed decent enough. Well recently, I was at a buddies place and was listening to some tunes (Pink Floyd, Satriani, etc) and commented that his system sounded really damned good. He proceeded to tell me that it wasn't the system so much as the source. He had a library of FLAC lossless stuff that had been transferred by audio nerds from really good vinyl sources. We switched back and forth from some of the duplicates that were on his Ipod from the iTunes store and the FLAC stuff, and jesus what a difference. Particularly notable was the crisp seperation of sounds towards the high end, and the discernible punch of the low end as well.
Came home, checked it out on my much less expensive hardware, and sure enough, a big difference.
Anyone else notice this?
Yes, I know I'm probably many years behind the cue ball on this one.
Makes me wonder when/if any industry movers and shakers will start offering a really decent digital audio player/file format. I imagine if Apple brought out iTunes HD Audio section, a lot of people would buy much of their libraries all over again just for the big difference in quality.
Back to tunes...
I use FLAC just because I can transcode it without the huge loss in quality lossy -> lossy gives. I can't hear the difference between a FLAC and a -V0 but if I'm paying for it I have to have FLAC.
I also wouldn't say vinyl is innately better than CD. Its just different and depends on a mastering a lot more than the actual medium. Thats why a lot of older stuff may sound better on vinyl than their modern CD counterparts they're mastered differently.
Just noticed that iTunes offers an Apple Lossless format option for ripping CDs. Is this the same encoder as libALAC on CUETools?
In my experience, modern vinyl sounds the same as modern CDs due to the way music is produced anymore. People claim things sound "warmer" on vinyl, but that's because of the slight difference in sound the hardware makes. You can equalize your digital output to sound exactly the same if all other equipment is the same as well. Unless they master the vinyl different than the CD, there's no difference on identical hardware properly leveled.
This has nothing to do with the compression and everything to do with the mastering. If you take those FLACs and convert them to 192 mp3, you likely won't be able to hear a difference.
What your friend demonstrated to you is the effect the "loudness war" has had on music in the past couple decades. Even old music, when reissued, is being released with dynamically compressed mastering and even heavy clipping.
The reason for the change is twofold: The most cited reason is so that the music sounds louder on the radio than other songs. The more important one (IMO) is that most people listen to music in noisy environments nowdays. It's hard to hear quiet tones while driving in a car, or over crappy earbuds on a busy street, so they flatten out the mastering so that you can hear everything no matter how loud the background noise.
There are some labels/producers that still make music with a high dynamic range (T Bone Burnett comes to mind), and some labels will separately master their vinyl and SACD prints to have better sound.
Yes anything ANALOGUE sounds better than this digital garbage!Arkaign said:Anyone else notice this?
Mmm listen to that 320 kbps silence. Go variable bit rate and save yourself the trouble and hard drive space.
Would be an interesting exercise to compare the waveforms of the line-outs from a CD player and a vinyl player, with the same recorded music.
i really miss allofmp3 and their customizable quality DLs of questionable legality....
In general and IMHO, here is what makes the most difference in sound quality (in order):
1. Original recording and mastering quality. No matter how good is your audio system, garbage in = garbage out.
2. Transducer quality (i.e. speaker/headphone) makes the biggest difference out of all audio components.
2b. If speakers are used, room acoustics can make good speakers sound bad and bad speakers sound even worse. Reflections, echo, shaky bass, all can harm the enjoyment of audio performance. Proper speaker placement and calibration is important.
3. Digital-to-Analog conversion of recorded media/file and bitrate of the file. Noise, distortion, high jitter, latency, can all have a bad down-flow effect on your audio system.
4. Amplification of your transducer should be sufficient and beyond minimal specs.
5. Misc components that make insignificant or no difference (cables, power filters, accessories, etc).
6. Good hearing and understanding that it doesn't take a fortune to build good audio system.![]()
