I had no problems connecting my L1 bridges on my Athlon 850 for o/c using a pencil. I started getting errors that would go away at default settings (voltage, speed), so I figured it was just the pencil lead wearing out. I went to AutoZone and got the Defogger Kit for a more permanent solution. Now I cannot get a succesful unlock. I can't increase the multiplier. (ex. 100*10 == 600) It works at default though. Is this definetely crossed L1 bridges? I did accidentely get some AS2 smeared over some of the other brideges, but I'm 99.9% sure I got it all cleaned off with NailPolish remover and Rubbing Alcohol. Any suggestions? Do you think its the L1's or possibly something else? Thanks in advance
