I won't bore you with the details of why I needed to do this, but I did. I normally run Vista 64 bit. I made two new partitions and put Vista32 bit on one, and Xp 32 on the other.
With just Vista 32 and 64 installed, I could choose between the two operating systems at startup, no problem. As soon as I installed XP 32 bit, my computer could only see XP, and would boot right into it. So, I installed EasyBCD and Vista Boot Pro and told them to install the Bootloader ( I don't remember if I told it to do all drives or all partitions)and once again I could choose from all three operatiing systems at boot up.
Now here is my problem: After all three operating systems were installed, I then reinstalled Vista 64 bit (my original OS), and now the computer boots right into Vista 64, I get no options for the other OSs at startup. When I run the install Vista Bootloader from EasyBCD or Vista Boot Pro, it still doesnt see the Vista 32 or the XP 32 operating systems.
Do I need to completely reinstall them again now, or is there some way to make it see them.
Here are my 4 partitons and how they are shown in Disk Management:
C: Vista 64bit - Healthy (System, Boot, page File, Active, Crash Dump, Primary Partition)
D: Storage - Healthy (Logical Drive)
E: Vista 32bit - Healthy (Primary Partition)
F: XP 32bit - healthy (Primary Partition)
I am not sure why or how my storage partition became the Logical drive or if it matters. I am not really very knowledgeable about drives, so I don't actually know which drive should be logical or if it matters. Would making the C drive the logical drive allow my system to see all the other operating systems at bootup?
I feel like kind of a novice on this topic. Thanks for any help.
