Multi-monitor on linux - anyone done it?
Hi.
Right now, I've got a Win2000 Server running dual monitor. Primary video is the built-in AGP on a Soyo motherboard. Secondary video is a PCI Voodoo-3 video card. Runs great.
I wanted to investigate linux as an alternative OS, but had difficulty in finding any info on multi-monitor setups under linux.
Any info greatly appreciated. Actual comments of "I've done it" or "It's impossible" also welcome.
Thanks.
Sure. I've run multimonitor setup In linux before you could realy do it in Windows. (win98 could do it, sortof, but it was retarded). And actually I've using it right now on my desktop.
Hell I have a triple setup I use sometimes, 1 crt, 1 lcd, and 1 TV. Doesn't work out all that well though, due to the propriatory nvidia drivers. Much easier when you don't have to depend on those (but then you loose 3-d acceleration).
There are several ways to do it. The easiest to look up is xinerama. That sets it up so that you have 1 big desktop made up of 2 monitors. Other modes include having 2 seperate desktops you move focus back and forth with the mouse.
If your cards are well supported it should work out. I don't know what your on-board is, depending on that it can be very easy to moderately difficult (having to edit the configuration files themselves.) Nvidia on-board would make it moderatly difficult.
But if it's Via vid card or Intel it shouldn't be to hard, but it's hard for me to know because i've never used a Voodoo-3 card in Linux, and I don't know your on-board.
Most of the time it will be detected at install time (unless you use a more primitive install type like Debian, Slackware, or Gentoo), and it will give you a chance to configure it. (which side is the screens are in relation to each other, monitor type if it can't be autodetected etc etc). If not then finding the display settings and mess with it their.
Worst case is that your just going to learn how to edit the /etc/X11/XF86Config or /etc/X11/xorg.conf file, but you'd probably have to do that eventually anyways if you use linux for any length of time. Nothing beats being able to get stuff exactly the way you want it.
For instance I have 3 setups so that I can use 2 screens, or all 3 (rarely use), or just 1. That way some games like ut2004 have a hard time dealing with dual cards, so I just restart X with the 1 screen setuip.
ya. Don't worry about it so much. Just install Linux and figure out how to do it when you have the OS sitting in front of you.
There is a lot of out-of-date stuff (check the time stamps on pages), and unless you can see what your reading about in front of you, you'll probably just confuse yourself.
At least that's what happens to me.
originally psoted by: silverpig
I have vga -> monitor and s-video -> tv working right now.
Ditto here. Plus my sound card is hooked up to the home theater system. Took me a while to configure, but the end result was sweet. Now I can watch all my pr0n and avi movies on tv !
🙁 my tv is RCA-type plug in, only. My video card is S-video out.
I have a cheapo cord that tranlates the s-video to rca, and it does ok. But it leaves a black bar going across the top of the tv... A little one, but it makes the picture scewed a little bit....
*sniff*
Oh, well. What I want next is a computer-type projector. Like the ones used in presentations or in classrooms. Then I get my "real" home theater going. 🙂
