Multi monitor BF3 and Vram usage
houe
316
Anyone here able to give some idea of vram usage when running triple monitors? Trying to figure out if a 1.5GB 580 SLI setup is going to make it happen or if i need to spend the extra for 3GB cards. Its very tough to track down information since so few people run such a set up. Thanks!
Grooveriding
9,147
1,329
What settings do you want to run ? Do you want to use AA ?
You need to decide on that first. I'm going to say you will not have enough memory. I need to use 2xAA instead of 4xAA @ 2560x1600 because of not enough memory.
But, if you played on medium, you might be able to manage it.
houe
316
I think I'll start out gaming at 1920x1200 however I want to keep the option for 3 monitor gaming available when/if I move to SLI. So 5760x1200 potentially.
Madcatatlas
1,155
Edit: holy crap there IS a 570 with 2.5GB ram... Why did noone make a topic about this?!..
Do you lack basic understanding of how the VRAM on a graphics card work when in CrossfireX/SLI Keysplayr? Or is there a 570 with 2.5GB ram out now?
Grooveriding
9,147
1,329
houe
316
People interested in multimonitor gaming are really the main people interested in these higher ram products it appears. The question becomes do you run out of ram or gpu power first?
digitaldurandal
1,828
AT this resolution 2gb might not be enough for some games.
Haven't seen any games hit the cap of 2gb yet personally - and if they did I think you would need more than 2 cards to run at that resolution at that point making it mostly a moot point.
I know I am hitting the 1.25gb cap with 2x570s; running all high, no motion blur (who does!? omg it makes me want to vomit so much) and no hbao 4xaa 16xaf
if i turn on hbao i get major stuttering, turning it off seemed to solve the issue at least on the available map, may be that on other maps i may have to turn down aa a notch remains to be seen.
