MSN Messenger problem
nags
128
I've been tweaking my computer all day with the instruction of several websites. Been doing a lot in the registry and everything has been working very well.
However, earlier I ran a script to get rid of the popup messenger program and I think I may have ran the wrong script or something, but ever since I cannot run MSN Messenger. At first I was getting errors so I uinstalled and reinstalled it. Now it will simply not open. I even tried restoring my computer to its state from yesterday.
The operating system is XP Pro.
Basically, I think I just need to undo what this script did but I'm not sure what I need to do exactly.
Here's a link to the page with the script - http://www.dougknox.com/xp/tips/xp_messenger_remove.htm
thanks
1sikbITCH
4,194
574
I don't know how to fix your problem, but I do know how to do what you set out to do originally.
Open Start/Control Panel/Administrative Tools/Services.
Scroll down to Messenger. Right click, choose Properties. Change Startup Type to Disabled. Hit Apply or just close the window and that's it.
vailr
55
I looked at that web page, and you should be able to undo by:
Start/Run/regedt32: go to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Outlook Express
Find dword: "Hide Messenger".
Change the value from "2" to "0".
Or, right-click, delete this dword.
Edit: Just checked my registry, and that dword is in there, with a value of 2, with MSN Messenger running fine also.
Did you also uninstall Windows Messenger , using Add/Remove Programs//Add Remove Windows Components?
That is: if you install MSN Messenger, you should also uninstall Windows Messenger.
nags
128
Yep, I did all that... Uninstalled the newest version then uninstalled it from Windows components.. then reinstalled both.. still doesnt work. I dont even get an error code or anything
Just says this "This application has failed to start because the application configuration is incorrect. Reinstalling the app may fix this problem"
vailr
55
No, you don't need Windows Messenger installed at all,. The "Messenger Service" (Start/Run/services.msc) is also not needed and can be set to "Disabled". With Windows Messenger uninstalled, (and also "Messenger Service" disabled). Only THEN, install MSN Messenger.
nags
128
Just did that and nothing changed... Still getting the same error :(
apoppin
34,890
alienbabeltech.com
I already went back several days and it did not fix the problem
Ouch!
Try going back further. If not, you might be out of luck . . . some registry problems are pretty hard to track down - I guess the XP "repair" function will not work also . . . i am always very cautious about running (untried) Visual Basic Script file programs on my registry instead of manually editing it . . .
reinstall XP?
or e-mail Mr Knox.
good luck . . . I am out of ideas. :(
nags
128
Well, I know exactly when it happened so I first tried going back one day. That didnt work so I went back a week and a half. Still no change.
Does XP work like 95/98 in that you can install itself over the existing copy and replace and damaged or missing files? Maybe I'll try that.
apoppin
34,890
alienbabeltech.com
My experience with XP is limited (I have Win2K but have troubleshot a few XP systems). Restore should work. You DID pick a "restore point"?
With both Win2K and XP, you boot from the CD and choose "repair" . . . I would certainly try that before thinking of a reformat.
Or try bumping this thread tomorrow morning to see if you can get additional help from a Registry Wiz.
nags
128
ok, well now I uninstalled all instances of MSN Messenger and let Windows Update install version 4.7 and now 4.7 is actually working.
However, I still can not get the new version to work.. Getting the same errors
nags
128
Got it working!
Here's what I did if anyone has a similiar problem.
Deleted ALL instances of MSN Messenger.. Then ran Windows update and had it download Messenger 4.7.
I then installed Messenger 6.1. At this point 6.1 still did NOT work.
So then I ran the setup file once again for 6.1 and chose the 'Repair' option and VOILA!
It now works.
Thanks for all your help :-D
