MSI6380 Pro, started to make a siren-like/whaling sound.
IsOs
It locked up then I rebooted and all I got is this sound instead of the normal 1 beep. Anyone have ideas where should I start?
jfunk
1,208
I believe that is generally a temp warning.
Check your fans/heatsink.
j
IsOs
I open the case and found 2 capacitors next to the ATX power connector open on the top. The motherboard is dead. Could this be a power supply problem?
IsOs
For people curious what it look like:(
No other component appeared to have any physical damage.
I tried looking for these capacitors 4700uf 6.3v. They're were not available here locally. The nearest I could find locally is 4700uf 16v - about 1/8 inch too wide to fit side by side in the motherboard.
Unlike my previous experienced, where the system actually
got on fire
