MSI Z97 SLI +, ASRock Z97 Extreme4 or Extreme6
Best Motherboard
  • MSI Z97S SLI +
  • ASRock Z97 Extreme4
  • ASRock Z97 Extreme6
  • Other Sub-$150 Board That Supports 2 Way SLI (Please Specify)
ctk1981
1,464
I vote extreme6 since that's what I ended up going with. Just remember if you use the ultra 2 slot you wont be able to do sli due to four pcie lanes being used for the ultra2 on the extreme6.
Maximilian
12,604
15
Extreme4 for the dual bios, no outdated PCI slots and I guess the 12k caps are nice as well although it'll probably be obsolete before something like that matters.
you2
7,071
2,123
They are not identical; for example the MSI has alc 892; while the asrock as alc 1150 for sound; the MSI board also lacks display port (important for high resolution monitors).
The msi board does have pci slots (important if you have an old pci device that cannot be replaced via pcie (I have this issue).
The extreme6 has 10 sata ports (if you need extra sata ports). There are a few other differences between these systems.
I'm personally going to go with the extreme6 since we have a local micro-center and the bundle is a good deal; just have to find a work aroudn for lack of pci slot first.
