Solved! msi z590 cabon wifi i9 11900k cpu red light on for cpu not detected
Sammy22
7
I have just built a new computer it is a msi gaming carbon wifi z590 and i9 11900k, when i turn it on i have no post display. the red light is on for cpu not detected or fail. I have checked the cpu and cables, all are ok. can any one help please Sammy Help Still in trouble stripped and rebuilt but still cpu not detected PLEAE HELP
Solution
Hi Guys, Thanks for all your help I purchased a new motherboard and the problem is sorted. I purchased a same new one as I would not be able say if it was me at fault or it was faulty thank you everybody Sammy
Hotrod2go
349
233
86
Is the 6 pin PCIe connector plugged in at the bottom of the board? I had the same issue as the OP with my Unify board & thought it was for an extraordinary powered GPU at first. Afaik MSI are the only vendor to do this with mid to upper Z590 boards. They have designed the cpu power wiring on these boards in a unique way no doubt.
Sammy22
7
I have tried and checked pci cable all ok , i have also stripped and rebuilt removed and replaced cpu tried without pci and hard drive still no cpu detected, the cpu is a i9 11900k unlocked, idont know if that is the problem. Thanks for any help you can give me. Sammy
Hotrod2go
349
233
86
Well if your sure all the necessary power supply cables are plugged into the appropriate sockets as outlined in the mother board manual & that most certainly is a supported cpu the 11900k.
If the board is mounted in a case, take it out & test on a wooden board or rubber mat. You could have a short somewhere. The debug light for cpu & other components should light up if there is a problem apart from shorting.
Sammy22
7
Hi, thanks for your help. I have previously fitted this in another case with same result, i will try it out of the case, if I get the same result, does that mean the cpu is faulty, i want to make sure, as it is £500 for a new cpu, I just wondered if it was because the cpu was a unlocked type. I really thank you for taking the time to help me. thank you sammy
Hotrod2go
349
233
86
Nah, your choice of an unlocked cpu will have no bearing on if the board works or not. Only in a very rare situation IF the cpu is faulty would that be the case. To rule that out, you'd have to run the cpu in another board to be sure.
A good general rule of thumb in this scenario is to test the suspect item with known working components in order to isolate the faulty item.
Sammy22
7
Hi, Thanks for your reply, I dont have another i9 computer, so it looks like I will have to buy a new cpu. I have checked the motherboard out of the computer with no graphics card and it still no cpu detected. Thank you for all your help and time. Sammy22
Tech Junky
3,825
1,343
Get a PSU tester to make sure you have power to all leads connecting to the MOBO.
They're maybe $20 on Amazon and can save you a headache of swapping things if it's just the PSU that's acting up.
blckgrffn
9,681
4,325
www.teamjuchems.com
I would definitely get a motherboard to test with before dropping money on a new CPU. Even a B560 board can be used, it doesn’t need to be fancy, it only needs to have that CPU on the supported CPU list.
I would stay away from 4xx series chipsets because 11 series CPUs were not a sure thing with them, and likely required a bios update even if they did support them.
I guess you could also buy a pentium/i3 to test your board but a bad CPU seems way less likely then a board that needs to be RMA’d.
Reactions: Hotrod2go
Sammy22
7
Solution
Sammy22
7
Hi Guys, My z590 motherboard working ok except one problem. I have updated my bios, but it still shows incorrect memory speed. Can anyone help. Thanks Sammy
