- Dec 31, 2010
- 1,772
- 1
- 0
Agreed except for the galaxy blue PCB. What were they thinking.
Everyone knows green PCB is better quality anyway.
still wouldn't be single slot though D:
wow, is that card single slot..? (certainly appears that way from the pictures)
Unless your supremely confident in your ability to install a full water block and that the ram and VRM's are going to be cooled correctly (the first install/attempt) it would be not smart to try to save a few bucks and not buy a pre-installed water block. Even more son on a 500 dollar card. You want to decrease the chances of having to drain and tear apart your rig. Imho.
EVGA is a FTW card... so best binned cards, faster stock speeds, etc...
Lifetime warranty on the entire card AND waterblock is worth the extra coin imho
The binned card is probably the best reason IMO. All EVGA (AR) cards are lifetime warranted even if you install your own water block. The warranty is good as long as you don't physically damage the card during install or get it wet. I'm pretty sure the getting it wet part still voids EVGA's own water cooled cards as well.
The advantage to having the air cooled card + separate block is resale. It is much, much easier to sell a used air cooled card on ebay than it is to sell a card with a water block only.
oh yeah... for sure. I guess i never think it out that far (reselling that is)![]()
Evga also includes OCing in their warranty. If I was to buy a product of this caliber and price, I would want that coverage for my sanity. I would be afraid to OC a card that expensive, have it fail and be out the money. MSI doesn't cover OC so, no money from me unless it is a part I plan to use stock.
I'd love to see the quote from EVGA about overclocking being included
