msi ti-4200 fan noise?
dighn
22,820
4
is it loud like they say for the 4400/4600? the last thing I want is to add more noise to my PC with the FOP32 in there already. most of you probably dont mind with your delta and the zillions of fans in your case but i want to know if it is loud or not ;)
it's got a good price for 128mb and some good bundled titiles (NOLF & sacrifice & equnox) but if it's loud then those good points are moot, it would be crap.
KnickNut3
2,382
Definitely like a plane taking off. I gave up VIVO, the lower temps, and the games for the quieter Abit Surilio. Check tomshardware.com. They have a sound test in their GF4 run-off.
dighn
22,820
4
hmm taht's for the ti4400/4600 though. you don't think they'd listen to the reviews and change the fan in the 4200?
oh well that's too bad... ack if they use the same fan from the 4400 then it's definitely out of the question.
