MSI RS480M2-IL + cpu temps
prizm
I would like to know the temps of ppl who have this board and their cpu and how they monitor their temps in Windows.
Thanks
You can download a piece of software from MSI's site that allows you to monitor the CPU temps. I have forgotten what it is, but I used to have that board and it worked pretty well. I am not sure it reports them correctly though, because O couple fo times it defied physics. *smirk*
My temps are typically 29C idle, 37C under load. The Chenming MATX-118 is a great SFF case design for cooling. I overclock with ClockGen and have even disabled C'n'Q. Temperature readings are consistent within one degree as checked by the Bios PCHealth, the MSI utility and the case sensor.
