What kind of temps should this card be running?
It came stock at 880Mhz Core / 1250Mhz Memory
I OC'd to 925 Core / 1250 Mem on the stock voltage. (will probably push more just testing it out)
I installed MSI Afterburner and turned on Voltage monitoring
Stock voltage seems to be 1.081 max and drops down to 0.949 when it clocks down to only 500Mhz core.
When playing games (Just World of Tanks and SWTOR so far) the Temp hovers around 64-66C but the fan speed is only at like 47-49%... I've never seen fan speed go above 50%. I manually set the fan to 60% and the temps dropped to the mid 50's in those same games...
Edit:
While sitting here typing in forums it dropps down to 45C with Fanspeed at 36%
Should the Auto fan be doing better or is it okay to sit at 65 degrees all the time in games with fan at only 49%
Edit:
