I have my system up and running, now my husband wants to add his old Quantum Big Foot 6G hard drive into my system since his power supply just crapped out. I have a 45G IBM 100ATA inside using the 100 ATA ribbon cable that came with my mb.
Could I use the same ribbon to make this a master/slave configuration or should We use a seperate ribbon and put the connection into IDE2 on the mb since this his HD is not 100ATA?
If we do seperately, one cable into IDE1 and the other into IDE2, would there be any problems with boot partitions, etc.? It came out of his Compaq 233Mhz model 4814.
We don't want to erase anything off his hd so I guess for now it would have to be the primary hd. It has W95 on it. Is this possible? If I first put Windows 2000 on my IBM would I be able to import this older hd?
Thanks, all
TGirl
Thanks, all
TGirl
