MSI P6N SLI Platinum overclock problems
stargazerxc
Hi,
I am new here, I am not sure should I put this topic here or overclock section, but I put it here anyway.
I recently bought a MSI P6N SLI Platinum. I want a good quality board with nice overclock ability and not too expensive. Seems MSI P6N SLI Platinum is what I need after read the review on this site.
The board works pretty nice except the overclock ability. I only reached 1440 FSB, result 3.2G on CPU, anything higher than that just won't post. I am not satisfied since my CPU is E6600 and i am using water cooling system here. I read the review on this site said it's easy to get over 1600 FSB with stock cooling. I used excalt voltage setting in the review, upgraded the bios to 1.22. Disabled CE1 and other spetum settings. Is there anything I missed or just my bad luck?
Any reply will be appreciated. Thanks
Gary Key
866
PM me your email address and I will send you the latest performance BIOS, overclocking is improved. We will get you to 1600.... :)
Assimilator1
24,152
517
I might be getting this mbrd ,what's the typical FSB they can achieve?
Talking of 650 mbrds ,is their any group reviews of these?
