I would appreciate some help figuring out how to plug in my front panel audio connections. Here are links to the manuals for the case and the motherboard.
http://us1.msi.com.tw/files/downloads/mnu_exe/E7350v1.0.zip
http://www.coolermaster-usa.com/Downloa...ation/Elite%20330-331-M_RC-330-331.pdf
The manual for the case doesn't label the wires the same as the labels on the product. They are actually labeled:
Yellow - MIC-IN
Red - MICPOWER
Black - GROUND
Brown - R-OUT
Brown - R-OUT
Orange - L-OUT
Orange - L-OUT
Both browns are connected to one wire, much like molex power connectors plug into a hard drive and split off for another connector. The oranges are the same.
As you look at the diagram of the motherboard's front panel audio connections on page 2-17 of the pdf inside the zip file, it does not have a plug for MICPOWER, but has both MIC_L and MIC_R, where the case only has MIC-IN and MICPOWER.
I won't say anything more as I'll probably just confuse you. If you would be kind enough to look at the manuals and let me know what I should do, I would appreciate it.
Thanks.
Yellow - MIC-IN
Red - MICPOWER
Black - GROUND
Brown - R-OUT
Brown - R-OUT
Orange - L-OUT
Orange - L-OUT
Thanks.
