Been having some issues with the power on this motherboard. A few things:
1)It goes to S3 sleep fine, but I can only resume it by using the power button (no USB mouse or keyboard wake).
2)It doesn't actually resume from sleep. I see the desktop for a second, then it resumes from hibernation...disabling hibernation causes the computer to reboot and I get the "Windows did not start correctly/Run in safe mode?" message prior to OS loading
3)This is the weirdest one -- if I shut the computer down, it turns off for about 4 seconds, then it magically boots up again without me touching a thing. The only way I can ensure the computer stays off after I shut it down is to turn off the power supply.
I replaced the power supply a couple weeks ago, so I'm pretty sure that's not the issue. I double-checked the pin connectors for the power and reset buttons, but I might check it again just to be absolutely certain. Could faulty power buttons be causing this, or is it probably a motherboard issue?
