- Mar 9, 2001
- 197
- 0
- 0
This is a continuation of a thread in the Hot Deals Forum.
I got my IBM NetVista Case today (off of eBay.) And I also got my MSI NForce MS-6353 motherboard in.
Guess what, it doesn't fit!
Bad news and Good news.
Bad News: The board doesn't fit the motherboard without modifications.
Good News: If you're willing to take the power supply unit, PSU, out of its factory mounted position, and craft a mounting for it so that it goes over the motherboard then you're ok. The motherboard is too tall (as the case stands) to fit. I've evaluated it a few different ways and figured out how I can put a mounting bar across the case and attach the PSU to it. When its done the powersupply will be more "inside" the case such that you won't be able to pull the power cord from the unit without removing the case, but that doesn't bother me. I really like how small and nice this NetVista case is, so I'm going to make it work and not worry if I can't unplug the power cable from the power supply.
I'll try to get some pictures later, no time right now.
Also, the screw that holds down the HDD bracket will be under the motherboard, so care will need to be taken to cover it with duct tape or plastic or something so that it doesn't scratch the motherboard.
Most of the screw holes line up, except for one corner, so that's not bad.
I think that's all I can tell about it so far, oh, there is a CDROM bay for those that didn't think there was.
