- Mar 9, 2003
- 677
- 0
- 71
I'm not sure if this is the right forum but here goes. I just received an MSI 875P NEO-LSR MOBO from Googlegear. In the specs it says 6 rear USB connections and 2 front on the motherboard for a total of 8 USB ports. Problem is the front 2 USB ports are supposed to go to header JUSB3. The 2 extra optional rear ports go to JUSB2 according to the manual.
Here's the kicker there is no JUSB3. The header is missing and never soldered on the board. Does this model come with the JUSB3 header or is that an option on the NEO-FIS2R board only. The specs do not specify it just says 8 USB ports for this board. It appears you can use the 2 optional front OR rear ports but not both but the spec says 8 total ports.
The board comes with a PCI bracket that has 4 diagnostic green LEDs on it and 2 USB ports. If you connect the cable for the 2 bracketed USB rear ports then there is no place to plug in the front 2 ports in my case. Anybody have this board and tell me if you have the JUSB3 header on it. Tech support at Googlegear was useless and MSI is unreachable.
One more thing. My Antec Truepower 430 supply has small a 3 pin plug with one blue and one black wire on the 2 outside sockets. The Antec Case manual says it is a "fan signal connector". I don't have a clue where this connects on the NEO-LSR board and the Antec manual for my 1080AMG case is vague at best. I checked the MSI manual and it appears that connector "SF1" is for fan monitoring but the pinouts don't appear to match. The motherboard appears to use 2 adjacent pins of the connector and the power supply uses the two outside pins. Any help here?
